Is there a way to make a dimension style that will automatically add a particular value to the dimension amount?
Example: actual dimension in decimal mode is 17.0 but i want the dimension to be displayed 21.0 (automatically adding 4.0 to it).
Please advise & thank you,
E.
I would suggesting scaling your dimfactor up by 1.2352941176470588235294117647059
Which is 21/17
eg. your dim factor is 10 your dim factor will become 12.352941176470588235294117647059
I used the normal windows calculator which is why there are so many decimal places
Howard Walker
You can try to use Tolerances, but then - you will get two values - real and "corrected":
Maxim
OP asked about adding fixed value to dimension, but when you change DIMLFAC, each dimension value will be multiplied by value of DIMLFAC.
Strange request any way you slice it.
IMHO it would be easier to just override each dimension manually.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
the only thing is that by overriding the dimension would become time consuming as i have a situation that calls for a large number of dimensions
i understand the tolerance option but do not want that displayed
as for the scale factor, that will not work either as it would not apply to a constant situation
(i.e. the 17.0 to 21.0 versus the 100 to 104 scenario which would actually take the 100 to 123/+)
thanks for all the replies
keep them coming if there is any hope in making this happen
It's kind of a weird request. An additive value to all dimensions will seriously misrepresent the aspect ratios of all your features, especially the smaller ones.
Hi xanadugod,
It seems I have found what you need.
You can change default dimension text with a help of simple AutoLISP routine (attached ZIP archive with .LSP file).
After you put dimensions, load the routine and you can use 3 commands:
1) DimAdd, you insert your value for add (or subtract if negative) and select dimension. Command has a filter for Dimension object, if you select a circle or line it is ignored.
This routine change text, in a internal database the text is stored with DXF 1, original value is DXF=42, these numbers you see in my routine
2) DimReset reset dimension to original value, because DXF 1 is stored to "" string
3) DimAddC permit add value to current text value, not original value. Example if you have line lenght 10, you have text=10, then use DimAdd and sum 100 obtain 110. With DimAddC you can add 20 to 110 and obtain 130, but with DimAdd you obtain 10+20=30 because refer to original length
And here is the source:
http://answers.yahoo.com/question/index?qid=20120312141641AAuIu8m
All kudos goes there
Maxim
Hi Dean,
You are right - my bad here.
Sorry about the confusion...
Maxim
I would create a block to look like a DIM using a line, use an attribute with a field to report the length of the line with a built in field formula to add 4 to the length. Insert the block at one point for the DIM then select the block and have a stretch action to place the other end of the DIM. It is slightly more work than normal dims because you need the additional click to activate the block before you can stretch it. It does have the advantage that with the measurement being an attribute, you can export all the DIMS out. I would personally make it stand out from normal dims (color or similar) just to avoid anyone elses confusion.
It's not a weird request. I would like this option too, because when we produce long sections for roading construction (for example), we are required to show them at a distorted scale (5:1). A datum is applied to the section, so if you want to do a dimension from the datum line to the "road" line, you will get a number that is five times the actual distance (you can scale the dimension to have this read the correct value), and then you have to add the datum number to it to get the actual measurement. If you could automate this process, it would be handy.
I'm using LT. I am trying the solution suggested by @steven-g , which could work. But I am doing a lot of googling to figure out how to do each of the steps. Will compile instructions once I have a workable solution.
I don't find a link to Google search results particularly constructive, though I appreciate that you responded. I mainly commented because people were saying they didn't see the point of @xanadugod 's question.
