AutoCAD LT Forum
Access Violation Reading
15 REPLIES 15
Message 1 of 16
ChrisBenefer
639 Views, 15 Replies
An error message appears each time a dwg is opened, after which I cannot edit or save any detail drawn, attached is copy of the error message as it appears usually three times after clicking ok
15 REPLIES 15
Message 2 of 16
pendean
in reply to: ChrisBenefer
Message 3 of 16
ChrisBenefer
in reply to: pendean
Thanks Dean, unfortunately when attempting to update as 1.1x64 error message states "this service pack could not be installed because it is not designed for the version of AutoCad LT 2011 - English that is installed on your computer."
I'm running Windows 7 Home Premium  - 64bit on a Toshiba Satellite Pro
Hope you can help
Message 4 of 16
Look at Help, About and up at the top left make sure the SP1 version you downloaded is the same as what you have installed.
Message 6 of 16
Hi Charles, thanks for the reply, appreciate your help. I'm running English version 3 would there be a conflict with that which is why I cant run the package correctly
Message 7 of 16
I was really interested in if you were running a 32 bit version of LT but had dowloaded the 64 bit SP.
Mine is a 32 bit SP1 updated version of LT. Yours should look something like this:
Message 8 of 16
hi Charles, apologies for the confusion...
the screen shot you took is very similar but says;- Product Version E.208.0.0 AutoCad LT 2011 - English Version 3
I've downloaded 64 bit update as thats the version of Autocad also installed, as far as I can see I'm doing things correctly but still cant run the update
Message 9 of 16
Have you tried the 32 bit update?
I'm not savvy enough to know if Version 3 means that both the service packs are already installed.
Message 10 of 16
I have, same results
Message 11 of 16
Think I'll try de & re-installing...start from scratch
Message 12 of 16
pendean
Version three means you have SP2 installed already, so your problem is most likely similar to the other links I posted (and may be outside of LT2011 to fix).
Ver 1 = no SP; ver 2 = sp 1; ver 3 = sp2
Mine also states Product Version E.208.0.0 AutoCad LT 2011 - English Version 3
Message 13 of 16
Charles_Shade
So for my information the Product info there will not tell you if it is a 64 bit version?
Message 14 of 16
pendean
in reply to: Charles_Shade
LT2012 64bit here and it looks identical to yours.
Message 15 of 16
ChrisBenefer
Guys, have de & re-installed, same issues after loading service packs on again, looks like youre correct Dean, maybe an external issue...? I really dont know...
I'm struggling now, AutoCad is pretty much useless at the moment, does anyone know or is aware of contact details for a tec at AutoDesk, if there is such a thing...paid a lot of money for the product with what seems little support, would have thought the discussion forum would be monitored
Really appreciate your help Charles & Dean
Message 16 of 16
pendean
Installation Help from Autodesk:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
Autodesk support is now on Twitter 24/5 (@autodeskcare): http://autode.sk/sbGrpx
Up & Ready Installation and Startup Help (free for new installs):
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=2786107&linkID=9240817
Safety Net / Per Incident Autodesk support (not free):
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=15892664&linkID=9240817
If you are on subscription, visit your Autodesk
Subscription Page for direct Autodesk Help:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=2915212&linkID=9240817
Customer Error Reporting:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=7047344&linkID=9240817
Different options that are available for self-help
technical support from Autodesk Product Support
E-Services:
http://www.youtube.com/watch?v=Ylj0o-R_Zn0
”Boost
