Just downloaded Autocad LT and started to draw. My lines are not visible in modelspace or in the layout, unless I roll over or select them. Only the endpoints are visible. I changed the color to be sure that the lines are not black or white like the backgrounds. I confirmed that the transparency is zero.
When I open drawings that I created in Autocad in Autocad LT, all the lines dissapear. How do I change this?
thank you
Solved by pendean. Go to Solution.
