AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
ACAD LT 2011 Crashes after inserting a block
1 REPLY 1
CMoran2014
396 Views, 1 Reply
I have tried numerous blocks that were created on my old XP Dell laptop.  I have probably 100 blocks I use on a daily basis.  After inserting almost any block (have tried over a dozen), when I click on that block, ACAD crashes.  I've opened the block file I use and ran a purge & "repair" and it found one error.  I saved that "repaired" file and tried to import it later; even on a blank page.  It drops the file correctly and looks fine, but as soon as I click on the newly inserted block; ACAD crashing.
I sometimes can get to "debug" option but ACAD closes up before I get  chance to look at it.
Here's my PC specs.
ACAD 2011 Lt 64-bit install on (Product Version E.208.0.0 English Version 3)
DELL M6800
Windows 7 64 bit Professional SP1
Onboard Intel HD Graphics 4600
NVIDIA Quadro K3100M
Intel i7-4800MQ 2.7GHz
16GB RAM
I am using a dual monitor display with two Asus V238H-P monitors.  After I initially installed ACAD I had some crashing issues upon startup.  After finding the 64 bit patches from the autodesk website, I was able to overcome that issue.
Any assistance would be highly helpful.  I'm going to try "Recovery" and see if that helps now but I'm getting very frustrated.
Corey
1 REPLY 1
CMoran2014
in reply to: CMoran2014
Ok...I think it was a slew of corrupted drawing files.  I "recovered" those drawings and then all worked fine. Robot tongue Hopefully that's all it was; but I really wish there were better diagnostics of ACAD crashes!  Robot Sad
”Boost
