When invoking the hatch command the window showing the hatch sample has some of the swatches either showing up dark or not at all. The dark swatches are mainly the line hatch and plastic. The hatches on some that I've added that are blank. Is there a way to adjust the way the display?
Are you still able to select a hatch and apply it?
Yes, everything works. It's just that the appearance of some of the hatch swatches for certain hatch show up either blank or black. It's almost like I need to adjust the scale so it shows up correctly. Maybe there is a way I can do a screen capture to show what it looks like
@RedClayAssociates wrote:Maybe there is a way I can do a screen capture to show what it looks like
While the dialogue is in focus (active), hold ALT and press Print Screen.
Send ACAD to the task bar (or not, I guess) and open Windows PAINT.
Hold Control and press V to paste the pic into paint.
Save the Paint file and then attach it to your post.
HTH
DJ
Those are custom, not core hatch pattern samples: most likely their coded scale is much larger than the small sampling AutoCAD creates for the display. No fix unless you want to rewrtie and recode all of those custom hatch patterns, manually.
Looks like you edited the core ACADLT.PAT file, considered not good practice by many of us that customize AutoCAD.
There is no fix except as I noted, check out the view the rest of us have of the core patterns.
