AutoCAD LT Forum
acad lt 2009 color line problem on monitor
1 REPLY 1
187 Views, 1 Reply
problem: when is in the drawing aerial orthophoto images as background, and
cadastrial maps on this images, lines seem to be darkness. yellow is darker
then must be, cyan to... even white lines is gray.
what can be wrong?
settings is by default, not modified yet.
another problem is with ploting, on the canon ir 2020 digital copier.
this aerial images wasn't printed, lines from cadastrial is correct.
config is P4 E8500, 4Gb ram, 250 sata hdd disc, nvidia 8600 gt, monitor
samsung 2032bw. win xp sp3.
1 REPLY 1
Video card color controls in Windows control your display.
Images color control needs to be done outside of AutoCAD as well.
Plotting is controlled by your driver, not AutoCAD if the preview looks
correct: many color printers and plotters should be professionally
color-calibrated before use for optimum output.
Dean Saadallah
http://LTisACAD.blogspot.com
Add-on products for LT
http://www.pendean.com/lt
”Boost
