Hi there,
To put a little life into this old topic, I've got a almost identical problem.
We're thinking about buying Acad 2012LT because our old Acad 2000i won't function anymore when we buy new workstations with Windows 7 (64bits) on them. We also use Solid Edge, so I already have a spacemouse and I'd like to use it in Acad 2012LT too. I've got a trial version of 2012LT on my workstation now and my spacemouse won't function with it. Is it possible to make it work?
Yours sincerely
Harold
Well that's kind of short...
Is there no workaround to get it functional?
What about this leonardl@cadsta.com from a message above?
Does he know a way to make it work?
Greets Harold
The mouse driver requires ARX ability not found in LT, but is in full AutoCAD (bet if you hop on their tech support website they will pretty much say so and offer no workarounds). Check it out, no need to take my word for it. Perhaps they've developed a Windows solution outside of AutoCAD/LT.
The folks you mention will sell you a $400 add-on to run ARX apps (or is it much cheaper these days) that, if you ever get audited by the BSA.ORG folks or Autodesk for whatever reason, it violates the LT end-user license and sets you up for a fine you can't fight off (they tend to get ugly and notify your professional organizations and local media of the violation too and I believe 'persuade' them to publish it). I personally would never put my company in that kind of negative risk, but to each his own, you are a grown up.
