AutoCAD LT Forum
AC2014LT block rotation
2 REPLIES 2
190 Views, 2 Replies
ive seen this question asked a few times, not sure why it isnt a feature yet. at least i cannot find it.
i have a ton of area id tags that need to be rotated in place. looks like the only option is to create some sort of lsp command for it.
if you have LT i dont think you can do this.
is there an alternate way of selecting multiple blocks and rotating them around their insertion point or something close to rotating them in place that LT users can do?
i have way to many to rotate manually.
Tags (3)
2 REPLIES 2
hwalker
Welcome to the Forums
A quick way is to select all the blocks. Right Click and choose PROPERTIES.
You will see down the bottom of the tab a section which says MISC. In there is a section called ROTATION. Put your angle in there.
Howard Walker
Left Handed and Proud
in reply to: hwalker
trying that now
”Boost
