AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
A customization sync error has occurred AutoCAD LT 2015
10 REPLIES 10
Message 1 of 11
apstevenson
1039 Views, 10 Replies
I keep getting a Sync Error message, constantly flashing away in the top corner of the screen. I'm online with no connectivity issues. This has basically ended up with all my custom workspaces dis appearing which I can set up again but I just want get this error message sorted.
Much Thanks,
Adam
PS - LT 2015, windows 7 (64)
10 REPLIES 10
Message 2 of 11
stevetamplen
in reply to: apstevenson
Adam,
There is a page regarding these errors I would like you to have a look at:
How to fix Autodesk Sync errors and how to update your clients
If those fixes do not eliminate the issue, please upload a screenshot or short video showing the flashing error message.
You might have a corrupt Windows user profile. Try creating, then logging into a new Windows user profile to see if that helps.
Best regards,
Steve Tamplen
Autodesk Support Team
Steve Tamplen
Technical Support Specialist
Message 3 of 11
stevetamplen
Also, if neither of the previous fixes help, you might want to try resetting AutoCAD to defaults to see if that restores functionality. Remember to save any customizations you have prior to resetting.
Steve Tamplen
Message 4 of 11
apstevenson
in reply to: stevetamplen
Thanks for your reply, the problem has just stpped on its own.
Message 5 of 11
cadmaster
I have the same problem and it hasn't gone away.
When I go to the 'How to fix Autodesk sync errors and how to update your clients' page and click on ' Autodesk Sync hotfix' - that page no longer exists.
Message 6 of 11
stevetamplen
in reply to: cadmaster
My apologies, they must have changed the link.
Here is the correct page, confirmed and visually verified:
Steve Tamplen
Message 7 of 11
cadmaster
Sorry, but I still get the 'Oops - that page does not exist' response
Message 8 of 11
pendean
Link works fine here on my mobile phone... .
Message 9 of 11
stevetamplen
in reply to: pendean
Sent the link to a co-worker and it works for him too.
Here is the bare link, try pasting it into the browser, and maybe try a different browser if it doesn't work there:
http://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcarticl...
Steve Tamplen
Message 10 of 11
cadmaster
The link you give takes me to the "How to fix..." page - what fails is the 'Autodesk Sync hotfix' link on that page that points to "http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19683742&linkID=9240618"
Message 11 of 11
stevetamplen
Hotfix - Persistent Autodesk Sync error in the system tray
Although this particular fix is for AutoCAD 2013.
What AutoCAD version and OS are you experiencing this error on?
Steve Tamplen
”Boost
