I've recently upgraded from 2014LT to 2015LT and now get horrendous screen flicker when moving, panning, rotating, zooming etc. This didn't happen in 2014LT.
Anyone out there got any ideas that might help solve the problem?
Try turning off Hardware Accelaration.
My want to check out this thread if you have the time. It's quite long.
Hope you find something there to fix your issue.
HTH
DJ
AcadAdamLT,
Thanks for your suggestion. I've tried all comsbinations of hradware acelleration on/off and smotth line display on/off but to no avail.
What's puzzling is I don't have the problem when using 2014LT which suggests the issue lies with LT20156. From this forum and other sources it seems to be a common issue.
nicks.
DJ,
Thanks for the suggestion. Took a look through the thread, turns out I'd already tried most of the suggestions but without success. Could be my graphics card but whether the I.T. police at work will replace it remains to be seen.
nicks.
Hello
Welcome to the Autodesk/AutoCAD Forums !
Have you a NVidia graphic card on your PC ?
If YES, have you tried to DISABLE the "FXAA NVidia Anti-Aliasing" feature ?
Then relaunch your LT 2015 ... and test ...
Patrice BRAUD
Pat,
Thanks for the suggestion, sorry it's taken ages to repond.
I've checked what type of graphics card I've got, I definitely don't have a NVidia card.
My PC simply states Intel(R) HD Graphics 4000.
From a quick look around this forum and others it looks like I'll need our IT dept to install a decent graphics card to solve my problem.
Nick.
