Good Morning All,
In the Layer Property Manager 2015 lt, if I select several layers to change more than one property -let's say I want to change them all to the same color and lineweight, or freeze, lock etc..- I can make one change, and then blamo - everything is unselected. I have to re-select the layers. The way it used to work, everything stayed selected until I made the call to unselect it. (Yes, I know, sometimes change is good, and the old ways need to change, but I'm a control freak, and if I select the layers, I want them to stay selected).
It happens with and with out layer filters. Windows 7, everything is up to date, yadda yadda.
Any insight? Am I missing a system variable somewhere?
Anne
Solved by rkmcswain. Go to Solution.
Set LAYERDLGMODE to 0 and try again.
Does it work now?
