I have quite a big file with photos and a lot of hatching, the drawing needs to regenerate almost every second action that I take. I would ignore it but in this version of LT (2015) the lines become big and bulky so I am forced to REGEN to bring them back to normal thickness. Is there a way to override this? I never had it in any previous version and would only REGEN if I wanted smooth curves on the screen, but this does it every time I move a grouped object or even copy a polyline. I have been forced to spilt my drawing across several files, which is rubbish!
Thanks for any help, it's driving me nuts.
Welcome to the Forums
Have you tried unloading the images. I have found if I have a lot of images in the drawing it slows my work down if they are loaded, but if they are unloaded (not showing) my work is normal speed.
Howard Walker
Thanks, I have changed IMAGEFRAME to 0 (IMAGEHLT is already at 0), LINESMOOTHING is off and I have unloaded all photos, although it may be the Adobe Illustrator vectors that are causing the problem and I do need them on the drawing. I will re-import all the hatching I removed to another drawing so at least I can keep the whole package together and I'll see how I get on.
It's curious, I have done way meatier detailed drawings than this in 2010 and never had this problem. Having angled curves doesn't bother me but having clonking thick lines that get thicker proportionately with me zooming out it a big pain. Is this a new trick from Autodesk?
Kinda-sorta. Dropping support for XP allowed them to move the graphics system forward to support DX11 (vs. DX9). Chances are you were working on a different system with the 2010 release, including graphics system, hardware, and drivers which had been established and stable for a good 4-5 years. New graphics system, new hardware, new drivers, new potential for problems. Like other major changes it will take a couple of SPs and/or releases to shake out the unforseen issues.
Thanks. I just hope they sort it. I have a completely new set-up with a massive graphics capability and super speed and memory but this is like designing in the dark ages. I rather miss 2010, I only upgraded after pressure from Autodesk and the new tactic to withdraw upgrades after next year.
Hello
Just a "stupid" idea : I hope you are running with VIEWRES and "Fast Zoom" ENABLED !?
VIEWRES <Enter>
Yes <Enter>
20000 <Enter>
Patrice BRAUD
Hello
The FIRST question just after the command VIEWRES !
Have you "Yes" as default setting ??
At the second question, you set 20000 ...
Patrice BRAUD
