I am trying this package and am having problems with printers. The package only sees the system printers consequently I am unable to make plots larger than the paper sizes they support (Tabloid). The windows version I have used (2011 LT) had drivers for DWG to PDF etc. which allowed me to select large sheet sizes in the layouts. I know that I can print to PDf using the Mac system but the largest paper size is limited to the installed system printers limitations.
Am I missing something ?
Mac Forum:
http://forums.autodesk.com/t5/AutoCAD-for-Mac/bd-p/520
You may have better luck in the Mac Forum
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Answered here:
http://forums.autodesk.com/t5/AutoCAD-for-Mac/2013-LT-printers/td-p/3398805
Maxim
Thanks for the circular link follow-up
