If I wanted to zoom to something just out of sight off the lower-left-hand
corner, I would roll the scroll wheel down (from wherever it happened to be)
until the proper area appeared, maybe hold down the scroll wheel to pan a
little and get the objects all on-screen, re-position the cursor over the
area of interest, and roll the scroll wheel up to zoom in.
Try rolling the scroll wheel back and forth as you hold your cursor over
different objects -- you'll see that the "center" of the zoom changes
depending on where you put the cursor.
I've attached a GIF showing what *should* happen when you roll the scroll
wheel. If your AutoCAD LT doesn't behave this way, there's a problem.
Kate Morrical
AutoCAD LT Technical Marketing Manager
http://blogs.autodesk.com/ltunlimited
"fourtiewheelie" wrote in message news:6380521@discussion.autodesk.com...
> Kate,
> I might not be describing my navigation issue correctly and the zoom may
> in fact be centered on screen like you say, but it is not centered on
> screen and on the cross hair. Currently in LT, say I want zoom in on an
> object or part of a drawing just of screen to the lower left. (yes I know
> I can pan) In order for it to come into view, I need to move the cursor to
> the upper right of the screen and zoom out until it appears on screen
> usually over zooming until what I want is near the center of the screen.
> This is not how a person navigates around a paper drawing, you don't look
> right to move left. I would like the on screen view to be centered on the
> cross hair while zooming.
> I realize that this is probably how it's always been and most users don't
> know anything else. I'll have to adjust or jump ship if I can't, an
> expensive mistake. I was hoping this was a simple fix, a system variable,
> maybe a macro.
> Todd
