AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
2010 is slow when selecting objects
9 REPLIES 9
Message 1 of 10
billythecad
3611 Views, 9 Replies
We have recently installed AutoCAD lt 2010 (couldn't upgrade from lt 2005) so it is a new install but we managed to migrate the custom setting from lt 2005. The following problems exist:
1)When selecting objects, it takes a short while to confirm the selection before other objects can be selected. This is a dramatic delay as this was not apparent on 2005 (or 2008 for that matter).
2)The cursor does not move smoothly across the screen when the objects are selected.
3)All drawings are slow to open and a save takes ages to complete
Is there anything obvious which needs to be disabled in order to speed things up (I have disabled transparency within windows and AutoCAD and turned off background publish/plot).
We are running the 5 user licence on 5 different machines and are all experiencing the same annoying slow symptoms. A sample of one PC's specification is thus:
Windows XP Proffessional version 2 with service pack 3
Intel Pentium 4 3.00GHz
2GB of RAM
Graphics card - NVIDIA GeForce FX5200
9 REPLIES 9
Message 2 of 10
Modman_4
in reply to: billythecad
The newer AutoCADs tend to chew up a lot of graphical memory for all the WOW factor visual effects. Try looking into your graphics card acceleration, and possibly turning off some of the visual bells and whistles if you don't need them. A big complaint is the Layer Properties Manager palette, and a lot of people have found immediate performance improvements once they switch back to the classic dialog box. The command is CLASSICLAYER.
As for slow saves, in my own experience I found the SAVEFIDELITY system variable to be the culprit behind extremely long saves. When turned on, which is the default setting, it will translate annotation objects into multiple copies in different scales and on different layers, for users of 2007 or older platforms. It also translates them back into a single object with many layer states again. This takes time. I went from 5 minute saves down to 13 second saves when I shut mine off. I also read a similar post yesterday with the same solution and it worked. If you have no users of 2007 or older in your office anymore, set that to zero. You can still save down to 2007, and just keep in mind if you deal with outside users with 2007 or older, you can always turn it back on just for saving and sending them your work. I hope this helped!
I hope my info was useful, but if by some odd chance it actually solved your issue, feel free to mark your post as "Accept as Solution". Thanks! 🙂
Message 3 of 10
LT is different in terms of what you can do with 3D, and that is where you
need the extra graphics. With LT, the old GeForce card should be fine as
long as it has 128 MB of video ram. Also CLASSICLAYER does not work with
LT. I really wish it did.
Brad
C3D 2010 on Vista Business 64 SP 2
LT 2010 on XP Pro SP 3
wrote in message news:6274354@discussion.autodesk.com...
Message 4 of 10
Migration may have hobbled your 2010 setup as well.
1/2/3 describe symptoms modman touched on, work through those items, as well
as the fact that you are running on a very old classic slow P4 with low end
RAM which does not help. 2010 is a resource hog.
Dean Saadallah
http://LTisACAD.blogspot.com
Message 5 of 10
Modman_4
Aack sorry about the CLASICLAYER. We only have full 2010 and LT 2008 here...
Message 6 of 10
Tudor_Timotin
I installed LT 2010 on a new machine a couple of days ago and I run into the same selection delay. I tend to think it's not a hardware related issue since the system I installed it on is brand new with the following specifications - Vista 64bit, 12gb ram, Nvidia Quadro FX 3800 1Gb and dual xeon E5520 QC.I noticed though it does it a little bit less with VTENABLE - 1 (that is the animated zoom turned on). Maybe it can help you a little bit
Tudor
actually it was vtenable on 1 - it does it less, and not on 0 - I corrected it
Edited by: tudor4x4@gmail.com on Oct 22, 2009 4:30 PM Edited by: tudor4x4@gmail.com on Oct 22, 2009 4:31 PM
Message 7 of 10
billythecad
Thank you for the system variable advice tudor4x4. In fact, thank you to everybody that has responded. I have worked my way through the various comments disabling this and disabling that and AutoCAD is still running slow - even selecting objects to copy, switching to paper layouts etc.
Now that the problem seems to not involve the hardware (for tudor4x4 at least), I have been reading the reviews about Windows 7 and it appears to speed up the performance of both new and old PC's whilst all software and hardware appears to be compatible with it - maybe it is worth exploring this
Message 8 of 10
billythecad
I have been experimenting and have found good results in terms of improved performance when the following tickboxes are unchecked within the "options" dialogue box: Show shortcut keys in tooltips, show extended tooltips, show rollover tooltips, display paper shadow, enable background plot when plotting and publishing, display hyperlink cursor, tooltip, and shortcut menu, indicate selection area (within visual effect settings). Also I have switched the selection preview effect to dash.
Message 9 of 10
Modman_4
...in other words, you turned off many of the visual bells and whistles...
Message 10 of 10
billythecad
that's correct - I don't even have the properties palette permanently open any more which is a real shame - I can turn any of these features on as and when I need them
”Boost
