AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
2009 LT not responding after launch
6 REPLIES 6
CV200605
295 Views, 6 Replies
Recently, my autocad 2009 LT screen freeze after launch. The problem is still take place even if I re-install many time. Please kindly advice above problem. (I am using Window XP)
6 REPLIES 6
braudpat
in reply to: CV200605
Hello
Welcome to the Autodesk/AutoCAD Forums !
Just an idea : have you tried to install the SP/Update 3  for ACAD LT 2009 ?
http://knowledge.autodesk.com/support/autocad-lt/downloads/caas/downloads/content/autocad-lt-2009-up...
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
CV200605
in reply to: braudpat
It is still not responding after install spxSmiley Frustrated
braudpat
Hello
I suppose that the Windows Automatic Update has installed something incompatible with ACAD LT 2009 !?
or an other software ??
Can you restore your Win XP Pro to a date before 08-22-2014 ?
Patrice BRAUD
pendean
Unplug your phone and any other external device from your computer and see if that helps.
CV200605
in reply to: pendean
Hello:
The problem is still occur and I re-install programme again. The AutoCAD programe said exceed the number of Activation. (Error Code: 11). How can I do?
Bob_Zurunkle
You'll have to contact autodesk would be my guess. I had that issue before and they were very helpful. There is also a licensing and installation forum here that might be helpful.
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted 🙂
”Boost
