AutoCAD LT Forum
2008LT error during install on Vista
2 REPLIES 2
223 Views, 2 Replies
I am getting an error 1606: Counld not access network location Autodesk\AutoCAD LT 2008\R13\enu|.
I thought 2008 was suppose to be Vista compatiable.
Do I need to install this under compatibility mode?
I am also getting similar error while uninstalling Civil3D on a Vista machine. Would the two problems have a similar solution?
Vito
2 REPLIES 2
Seems to be a common problem with Vista.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
Has a solution been found yet for this common problem? I am unable to uninstall my 2008 version because of the same 1606 error, in order to try a re-install. This is to try to fix a Fatal Error I have suddenly aquired.
”Boost
