Script Error when checking license at first startup - LT2017
Message 1 of 8
I've recently just purchased and installed AutoCADLT 2017 and when loading for the first time, it freezes at checking license and I'm then presented with a Script Error.
I've attached the screenshot if anyone can help.
Thanks, Steven.
Replies (7)
Message 2 of 8
stevetamplen
Hello StevenJohnson;
Welcome to the Forums!
This is actually a fairly common error with 2017, and typically has to do with the language you have selected for your OS:
We have a known issue with the shortcut that AutoCAD creates on the desktop during installation interfering with Windows when any language other than English (US) is being used.
Can you please try the following to see if it helps?
Right click the AutoCAD icon, go to properties - on the shortcut tab, delete the /language "en-US" from the Target text box and then start the program.
Please post back to let us know if that works.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Steve Tamplen
Technical Support Specialist
Message 3 of 8
stevetamplen
@Anonymous
Did my post get your problem resolved?
If so, please hit the Accept as Solution button on that post so that others can find solutions more easily.
If not, please reply with additional details if the problem persists.
Steve Tamplen
Message 4 of 8
Hello stevetamplen,
Yes, YES!!! Thank you very much... your solution worked.
Once again, THANK YOU! Smiley Wink
Message 5 of 8
Script Error when checking license at first startup, am try to put licence but its showing script error
Message 6 of 8
Message 7 of 8
Message 8 of 8
i got same issue--Script Error when checking license at first startup autocad 2017 see attachment
