AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Scale in one dimension...
4 REPLIES 4
paul
3182 Views, 4 Replies
Dear AutoCAD Gurus,
Is it possible to scale an object in one dimension (e.g. horizontally only)...
I have a spline, that I want to scale in only the horizontal axis by 90%.  How can I do this?
Cheers,
Paul
AutoCAD LT 2014...
Tags (2)
4 REPLIES 4
pendean
in reply to: paul
Nope, unless the object is a block or made into a block first, then you can use INSERT or PROPERTIES.
paul
in reply to: pendean
Hmm, future feature request maybe?  I'm pretty sure Microstation can do this...?
pendean
in reply to: paul
If you need to use microstation please do: if it becomes an AutoCAD ability I suspect a lot if users would be happy.
AUGI.COM hosts AutoCAD's wishlist if you want to join and cast that vote.
paul
Your work-around did the trick, thanks.
”Boost
