Recenlty I've been getting a lot of runtime errors when carrying out basic commands in AUTOCAD LT 2011.
These can range from move, copy, measure and swapping between model space and paper space.
About 6 months ago I uninstalled al autodesk software from my machine and re-installed CAD, as I was getting a lot of Fatal error messages.
Could these be linked, is there some underlying problem with my desktop PC.
The Runtime error message says. 'R6025 - pure vertual function call'
Any suggestions
Rob Nash
Solved by Charles_Shade. Go to Solution.
Potentially this could be the PC. How long have you had it? Might be worth a Format of the Harddrive and starting over but that is a last resort thing to do.
If you can recall how did you go about the uninstall of CAD six months ago?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
It's a work PC that multiple people have used over the years, I think its about 6-8 years old with windows XP.
When removing the Autodesk software I either used uninstall via the start menu or add/remove program.
