I have Windows 7 running AutoCAD LT 2000. It was working and now it does not. It gives "FATAL ERROR: unhandled e06d7363h" when I try to open a file. How can I fix this
Wow, do whatever you did to get LT 2000 to run on Win 7 the first time.
XP wasn't even arounf then was it?
Seriously - Something changed on the computer and you need to find that.
Run a System Restore to a day or several ago as a start.
You can also try your query in the Autodesk Knowledge Base and look for the error code.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Thank you. I did run a system restore, but that did not fix the problem. It was a while ago that I installed AutoCAD LT 2000 and I don't remember exactly what I did. As I recall, there were some difficulties, but I was able to make it work.
David
Have you tried a repair install?
I would think to do this under XP Emulation mode for older software.
This is for more recent versons of CAD but maybe something similar happened to a DLL file in your case:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=9450349&linkID=9240817
(I have no idea if anything there is relevant though.)
