Hi everyone,
I would like to print my text layer in the color is in the model space (red) all the rest in black as usual. How can I do it?
J
Solved by john.vellek. Go to Solution.
It's simple. isn't it? We all time print out plans in black, I want to print out one of those layers in color (red color) the rest as usual in black just to remark a text.
Thank you for your help.
J
Do you use plot style table (Pen Assignments)? There, you can assign you your desire output color by using specific object properties (layer, color, lineweights, etc. ) and save it with your desire file name. Hope this will help.
Try it 🙂
HI @R4sso,
This is simple to do if you use plot styles. The only tricky part is if you have other layers that have the same color assigned to them. Lets assume that is the case.
So, for your Text layer lets pick a unique color in your Layer Properties Manger such as color 10 (assuming that your other layers and objects don't use this color).
Then, open your page setup or Plot window and take a look at your normal plot style. I will use Monochrome for mine. In the Form View, select ALL the colors on the left and then on the right side assign them to Black. Next select color 10 and assign it a Red color.
Save As a new Plot Style that you can reserve for future use.
I'm always open to learn more about AutoCAD which has been my favorite for more than ten years. I should has suppose the solution but I preferred to consult with this excellent team. Your response was part of that solution.
Thank you very much!
J
I am trying to do the same.
I have followed the instructions, but it is still not printing the selected color, regardless of what I print to (printer, jpeg or pdf).
Are there any other things I can be doing to ensure printing in color.
It would help us help you if you shared screenshots of your LAYER command and PLOT commands, and explaining which colors/layers are the problem.
OR
Share your DWG file here, explain which color/layer you are after please.
