I cant import pdf to dwg in the correct scale , when I import a line that is suppose to be 100 measures 7" or so just an example
I had the same problem (with Visio, but same idea) and got the answer yesterday. All credit goes to dgorsman: https://forums.autodesk.com/t5/autocad-lt-forum/scaling-from-visio-to-autocad/td-p/6917017
Try that- as long as you know one real dimension in your drawing, you can scale the whole thing with the "scale" command. You will then select your object/objects to scale, then choose a base point, then you will see two options for copying or reference. Type "R" there, then specify two points that make up a known length.
From there, you can tell CAD what the length should be, and it will scale your drawing.
To add try the following;
To properly scale the image to the appropriate dimension, you can use either of the following procedures:
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time
