STYLE command may be where you fix that: assign the correct FONT may be all you need to do, if that is correct then your other settings for that STYLE, but it appears you have a font substitution taking place.
That "bubble" is a block. Edit the block and stick a stretch parameter in it. Then you'll be able to widen the "bubble" to accommodate the text
Howard Walker
Oh snappers! Stretching the TagSlot block worked. However the horizontal leader extention did not move with the stretch. But funny enough once I move the leader around a bit in the drawing the snap point fixed itself lol
Thank you!
