I am using Autocad LT 2019. I have purchased online a Location Plan, scale 1:1250 & a Block Plan, scale 1:500 - both are .DWG files & have a scale bar as part of each drawing. However, before I even attempt to incorporate them into an existing drawing, if I just print them as they are, individually, the plans are very faint & when I check the scale bar against a scale rule, they are not the same. Am I missing something? Should I be rescaling?
As they are both different scales, will this make a difference when I place them both onto the same, already created drawing? Thanks for your help.
I would expect the the scale rule and bar to be the same when printed if the drawing was created to scale, and you are plotting to scale. A couple things you can check:
Plotting a layout in paperspace results in the the drawing not plotting to scale in AutoCAD
To Work With Plot Scale Settings
Please let us know if that helped.
You can use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
All the best,
Hi Cheryl, thanks very much I will try that this weekend, I am a very much a beginner so all help appreciated.
Hi, thanks, I really appreciate your reply, however, as you have guessed I am completely new at this & therefore am not familiar with some of the terminology I may need to help me.
