Thank you. Too bad the "help' section doesn't tell you this.
I was looking for this answer before on this forum but got a ton of useless garbage the screwed up my system really bad -- but I'm slowly getting back to normal now.
With all due respect, I have looked at "the whole Help Page" and that's why I use the forum because there is waay too much useless info on there that's massively confusing, contradictory, and leads to a 'rabbit hole' of irreversible changes that mess up the system. Now I am unable to open up multiple instances of AutoCAD where my SDI variable is set to 1....It was working perfectly yesterday but now it's not - even though I have not changed that variable. I am frustrated and feel like I am losing my ability to work effectively in AutoCAD with all these useless unproductive "computer settings' that take time away from actually doing real work. Any idea on the SDI setting?
Quit creating multiple posts then jumping around with questions from each of the others and mixing them all up.
Stick with your SDI post for your SDI problem. This post is about LOCKUI variable that has been around for a long time: what old version of AutoCAD/LT did you recently move from?
My Autocad LT 2000 doesn't have a command to lock the toolbar position so every time I close and reopen it, any toolbars along the top get jammed together on the left and the ones on the right slide back up to the top. A simple workaround for top and side docked toolbars is to create spacer toolbars using several blank user defined buttons as and put them wherever you want fixed spaces. Then, whenever you close and reopen Autocad, your toolbars are where you want them.
Good workaround. But usually, even in LT2000, you have to use WSSAVE command to save your workspace after moving this back around to where you like them.
Then and only then can you use LOCKUI command.
@pendean wrote:
But usually, even in LT2000, you have to use WSSAVE command to save your workspace after moving this back around to where you like them.Then and only then can you use LOCKUI command.
No, the Workspace feature started years later with .cui file in Version 2006
another trick is NOT trying to use docked toolbars, but floating toolbars!
If someone don't know how to move a toolbar as floating toolbar on a place where it would docked for usual: Hold CTRL down while you are dragging the toolbar by mouse.
(a bit more tricky is to save this for backups&recreate them, I prefer to use a Script .scr for it! The command for toolbars is: _-TOOLBAR)
