Recently when I go into ACLT I can only issue 3-4 commands before receiving the above error message with the question of "do you want to save work from last command?" Of course, I say yes and then am able to bring up the recovered dwg but within 3-4 commands it does it again. I noticed in 2004 several people had this same problem but I saw no resolutions to it. One Uninstalled ACLT and Reinstalled and it solved the problem, but I have already done that and it continues to do the same thing again. Am way behind on work so if anyone has a resolution would appreciate a response asap. Thanks.
