'm having this error when trying to open one file, in the same system another version autocad is working fine (2011)
I can't activate 2008LT. Please give me solution. I update ie7 also. Thanks in advance
Are there two problems here?
Can't open 2010 format (LT 2011) drawing in LT 2008 software? (Assumption)
Or cannot start LT 2008 program?
Please clarify.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
LT2008 does not open LT2011 format DWG files: could that be your problem, you need to save down?
If the problem is ONE file, fix it: RECOVER or AUDIT commands in whatever version of LT can open it, then remember to SAVEAS down to the 2007dwg version 2008 can read.
program not starting. i am installed today i cant activate this, but trail run is working. getting FATAL error while i click on activate.
Place to start:
Remove Autodesk Products:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240817&id=2887771&siteID=123112
Also:
Installation and Licensing Forum:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
If you're having problems on Windows 7, please note that this program is not supported on Windows 7. Please use Windows XP or Vista.
Unhandled exceptions are often due to corrupt .NET Framework. .NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
