Show only
Search instead for
FATAL ERROR: Unhandled c0000006h Exception at 645256abh
LT2007 requires the newer version to -EXPORTOAUTOCAD the file down instead of simply saving it down with a SAVEAS. I would take it a step further and knock the file to a lower format than 2007DWG as well.
I would recommend you all either upgrade the old LT2007 or downgrade the 'newer' version if you all plan on doing this type of exchange all day long with all the files.
On the newer version of LT, ask the user to go into OPTIONS command, the SAVE tab, and not only set it to a lwer format but to uncheck the two boxes below that as well. This might help all of you in the short term.
