Hello everyone, I'm Brendon and I hope you can help.
I've recently installed the 2017 Autocad LT and after having a couple of problems i went through and installed the various hotfixes and updates that were available and all seemed well, i've had no trouble all week since.
I came back from a site visit today and upon opening Autocad i received this error message (a splash crash i think they call it)
The code itself is different each time and i notice it states "violation writing" where most topics i've seen posted state "violation reading"
Can any body help with this?
I've gone through other topics and tried a few suggestions to no avail, theres been no updates or changes to the computer that i'm aware of ...
Many thanks,
Brendon
Solved by wispoxy. Go to Solution.
If you can open another drawing, the original drawing may be corrupt and require repair.
See: How to repair corrupt AutoCAD files
Reset AutoCAD to defaults.
See: How to reset AutoCAD to defaults
Turn off Hardware Acceleration.
See: Starting AutoCAD-based products without hardware video acceleration
Update your graphics driver.
Install the latest graphics driver from your video card manufacturer or use an AutoCAD-certified driver.
See: How to update your system to the latest certified video driver
Try logging in under a new Administrator Windows Account.
If you create a new account and can successfully open the drawing, you can either use that account or rebuild the user profile in Windows.
See: How to create a new local administrator Windows user account
Uninstall and reinstall the .NET Framework.
See: How to remove and reinstall the Microsoft .NET Framework
Uninstall and reinstall Visual C++.
See: How to remove and reinstall Microsoft Visual C++ Runtime Libraries
Clear the digital signature icons and then uninstall and reinstall the application.
See: FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at 4048b9h
If all the above solutions fail, you may need to ask the Community forum or contact Autodesk Customer Support.
Thank you for these solutions,
I will start working my way through them and let you know the outcome.
Is it worth stating that my autocad 2016 comes up with the same Fatal error message, but on another computer on the network the autocad is working fine.
Cheers Brendon
