I just started getting this error when I start AutoCAD LT 2010. I've tried the solutions posted elsewhere, i.e. removing Microsoft .net framework, including a complete uninstall using a removal tool posted elsewhere. I then reinstalled .net framework 1.1 and 3.5 SP1 from the Microsoft site, and the problem recurred.
The program worked fine until a few days ago.
The only thing that seems to work is uninstalling .net 3.5 using the Windows uninstall. The program will then load and run, but some commands will generate errors, including some fatal ones.
I'm using Windows XP Pro.
Any suggestions?
Bret Johnson
Solved by pendean. Go to Solution.
What other dot-nets do you have installed?
This Thread is looking for MS .net 3.0 to be installed:
http://forums.autodesk.com/t5/AutoCAD-LT/Cannot-Launch-AutoCAD-LT-2010/td-p/2462677
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Dear All,
I have got exactly the same problem.
Did anybody found a solution?
Regards
Nicola Onori
Elaborate on what you have tried please.
Downloaded and installed MS net 3.0
Restarted computer
trying to launch AutocadLT2011 .. same error
From Autodesk's Help:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7236884&linkID=9240697
In the right column you will see that this applies to LT 2010 too. Worth trying bfore starting over.
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
The microsoft update site installs .net 1.1 separately, and installing .net 3.5 SP! installs 2.0, 3.0 and 3.5. I uninstalled 3.5, but left 3.0, 2.0 and 1.1.
As I said ACADLT2010 will run, but still generates some errors. They are not usually fatal.
Bret Johnson
AFAIK, to fix .NET issues you must remove ALL versions from Windows, Restart Windows, then install only the ones you need in sequence. Most apps, when you start them, will let you know if the one exact variant they need is missing and you can download/install it later.
Here you go from Autodesk:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13109351&linkID=9240817
You may need to also remove all instances of Autodesk products from your system:
Remove Autodesk Products:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240817&id=2887771&siteID=123112
REVO UNINSTALLER, Google it, may be a better place to start removing the programs. Use its most aggressive settings.
..I "repaired" AutoCAD LT 2010 through the "installation utility" and now it's working
Excellent. Thanks for the follow up.
I think have this solved.
I did a repair reinstall on ACAD LT2010, and then installed .net 3.5 as a down load from the .net website, not the update web site. Everything appears to work so far.
Perhaps the problem is in the 3.5 SP1 update?
Anyway, thank you all for pointing me in the right direction.
Bret Johnson
