Fix your files by running RECOVER command while in a blank AutoCAD session.
Then PURGE, then SAVE, then QUIT.
Start a new blank AutoCAD session, set up all your office system variables,
text style, dim style, layers etc, then insert the 'bad' file, then SAVE.
Then Explode the insert, PURGE ALL, then SAVE. Run AUDIT, answer yes to fix
any errors found, then SAVE.
Next, make sure you have the latest Video drivers installed for your system,
lower the resolution to at least 1024, and color depth to 256. Restart your
PC. Now experiment with the files. Also have all LT updates installed.
IF you have any TrueType fonts, or logos from outside sources that contain
TTF fonts you do not have, eliminate or substitute them for SHX fonts.
Also, what is your Pickbox Size? Smaller is better, and less running Osnaps
is another solution too.
Did I forget anything else, people?
Dean Saadallah
http://www.pendean.com
"Angie Vaughn"
wrote in message
news:41A34FC1A1D46F6D9E1661FAFFFA9B5E@in.WebX.SaUCah8kaAW...
> I can't seem to get any work done for having to mess with my machine,
redraw
> the stuff that I lose when my computer locks up, etc.
> Does anyone know why when I try to extend a line/trim a line, I get the
> message. You have selected 1504 items. Do you really want to do this? (N)
> and then my computer locks up. I have to end task everything, and restart
> the computer?
> Any clue? I'm about to have to bring out the vellum and dust off my pens.
> I am running NT4, Autocad Lt 2000. My computer does this all the time with
2
> drawings in particular. Sometimes I lose the entire drawing, and it is not
> recoverable.
> Need help bad,
> Angie
