Hi folks,
I noticed a difference in my plots of solid hatches after migrating to AutoCAD LT 2021 recently. I've attached examples where you can clearly see notably more distinct hatch lines in the 2021 version.
The system settings for the both versions of LT are (or to the best of my knowledge, suppoed to be) identical. Anything happened under the hood between the versions that I might be unaware of?
Thanks in advandce,
Have you recently updated your PDF software?
Try my reply (8th) in the very old thread https://forums.autodesk.com/t5/autocad-lt-forum/problem-pdf-print-generates-strange-lines-over-hatch...
Howard Walker
Good catch! This should then be a problem for more ppl then me, one would think.
I've attached the file for your knowledge.
Yes, I have unfortunately already tried everything in that guide. But thanks anyway, I will open a ticket and post the answer here if it gets an solution.
