We recently updated our Autocad LT 2011 to 2018. We used to be able to copy & paste from Autocad LT to Illustrator with no issues, but now the lines from the 2d object we copy over to Illustrator are not connected and misaligned.
Here's an exemple of the issue. The 1st picture of the logo from Autocad LT and the 2nd picture is the result of the copy to Illustrator. Notice how the lines behave. Any help would be greatly appreciated.
Solved by john.vellek. Go to Solution.
Hi @Anonymous,
I suspect that Illustrator is not totally compatible with the new 2018 drawing format. As a test, save the file down to an older version and then Open it in Illustrator (rather than a copy/paste). Does this work better?
Hi @Anonymous,
I am not sure there is much that can be done with this issue but here are some additional suggestions:
