Welcome to the Autodesk Forums!
Assuming the white spot at the top that may be a graphics issue.
Are you looking for the drop down Menus?
Have you changed the CUI in some way?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Hello
Very strange !?
Have you tried to :
- Disable Hardware Acceleration ?
- Upgrade your graphic card driver ?
- Install the SP 1 for ACAD LT 2014 ?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22264544&linkID=9240818
Bye, Pat
Patrice BRAUD
Hi
Thanks u reply
nope , me is first time using this notebook , i no change anythig .
when i update to SP1 , for the right side ribbon is show out now , but the left side ribbon always hidden like this
if is the setup probelm , can guide me ??
Hi IPESWITCHBOARD,
The area is where 'Quick Access Toolbar' is and commands like New, Open, Save, etc. are located. As Charles and Pat already replied to you in the above, it could be a graphics issue or corrupted customization issue.
Normally, product repair or reinstallation will resolve such issues, but please perform graphics driver update and run 'Reset Settings to Default'.
Thank you.
Hi
Thank u reply
ok , i try ald , but still like this
this version can support win 8 ???
