style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"Homercad" <pgauna@fs.fed.us>
wrote in message
href="news:4944562@discussion.autodesk.com">news:4944562@discussion.autodesk.com...
then what I input in the Edit Design Control
dialog box. In the Ditch Control dialog box I have imput a foreslope
of 3.00 for both the left and right side. In the Slope Control I have
specified a Fill type of Simple with a typical of 3.00 and a maximum of 3.00,
for both the Left and the Right side.And I have also specified a Cut type of
Simple with a typical of 1.5 and a maximum of 1.00 for each side. Once they
have been processed and viewed I will sometime get certain stations that are
pinned to the end. When I view the cross sections and see some of the sections
that are "pinned" I will enter "A" to see the Actual control parameters and
see different cut info then what was initally entered. What is the reason for
this and how do I edit this to reflect the correct data. I know the
surface is rather flat where the cross sections are in question. Again thanks
for all responses.
wrote in message
href="news:4944608@discussion.autodesk.com">news:4944608@discussion.autodesk.com...
I forgot to mention that in the Section Sampling
Settings dialog I have a swath width of 50' for both the Right and the Left
side. When I import the daylight points into the drawing the stations in
question are exactly 50' from the alignment.
"Homercad" <
href="mailto:pgauna@fs.fed.us">pgauna@fs.fed.us> wrote in message
foreslope of 3.00 for both the left and right side. In the Slope Control I
have specified a Fill type of Simple with a typical of 3.00 and a maximum of
3.00, for both the Left and the Right side.And I have also specified a Cut
type of Simple with a typical of 1.5 and a maximum of 1.00 for each side.
Once they have been processed and viewed I will sometime get certain
stations that are pinned to the end. When I view the cross sections and see
some of the sections that are "pinned" I will enter "A" to see the Actual
control parameters and see different cut info then what was initally
entered. What is the reason for this and how do I edit this to reflect the
correct data. I know the surface is rather flat where the cross
sections are in question. Again thanks for all
responses.
