AutoCAD Land Desktop (Read Only)
what does this message mean?
1 REPLY 1
willpyle7693
396 Views, 1 Reply
Erro opening Point XDRef Database:
X:\Projects\.........\Cogo\XDRefs.mdb
Unrecognized database format 'X:\Projects\......\Cogo\XDRefs.mdb
so far no complications with the drawing or the database. I just want this error to go away or learn what it means and fix it.
1 REPLY 1
Jeff_M
in reply to: willpyle7693
It usually means the MDB file was opened, and saved, in a newer version of Access. LDT requires the MDB files to be in Access97 format. If you are not using XDRefs (not many did/do), just delete it and copy one from your Prototype folders. If you ARE using the XDRefs, you will need to open in the version it was saved in and resave as an Access97 file.
