Hey Ozzie;
We assume that you are opening a session of Land Desktop instead of Land Enabled Map, but to check that could you go through the following:
If you open up Options, and then select the Profiles Tab is LandDesktop the highlighted Profile (meaning it is the selection as Current)?
See attached.
You "may" need to add the following after the "acad.exe" in the icon that you're using to launch LDT Properties utility;
Go to the Shortcut tab;
Find the Target reference;
Position your cursor in the Text Window to the right of Target;
Select the End key;
Paste ( /p "Land Desktop") after the (acad.exe") unless it is there already. I provided the parentheses for clarity only; you will not see them there. And please note the spaces within the parentheses - the spaces are necessary to this addition.
HTH
Don Reichle
"The only thing worse
than training your staff,
and having them leave is -
not training your staff,
and having them stay."
Courtesy Graphics Solution Providers
C3D/LDT/CD/SVY-2K6
Intel P4-3.00GHz
XPPro 32bit SP2
1GB RAM
Nvidia GeForce2 Ti 64MB
