Doug,
FWIW, Just an added thought...
Programmatically, one of the biggest stumbling blocks to accurate volumes is
the vertical boundary clipping planes at the limits of computation. While
composite volumes seem to do a very good job of dissecting sub-triangles of
both surfaces at the linear boundary of the controlling surface, Composite
Parcel sub-volumes are not as accurate. I can demonstrate this by taking a
site, dividing it into parcels, and summing the individual parcel volumes -
they will not exactly match the composite calculation done over the entire
site. I believe this is do to the fact that the triangles are subdivided at
the time the composite surface is created - in other words, the composite
surface contains sub-triangles which were cut accurately by the outer
boundary clipping plane. However, at the time the composite surface is
created - LDT is not aware of parcel boundaries and therefore can not
dissect the sub-triangles along parcel boundaries. Subsequent parcel
boundary computation is based upon that previously computed composite
surface and therefore needs to 'round' values at the parcel boundary. That
said and done, for most civil type work the error is going to be
insignificant (much less than 1%).
Note also, that as Marv has pointed out several times, you can have LDT
curved parcel boundaries, but parcel sub-volumes ignore parcel legs that are
curved and computes the boundary along the long chord - which could add up
to significant error in some cases.
sc
Doug Boys wrote in message
news:F0ECFE8B82184332BE5396F250B4C2BA@in.WebX.maYIadrTaRb...
> Be careful. Sometimes using Parcels to define volume calculation
boundaries runs VERY SLOW.
> I think it would generally be much faster to use each subarea closed
polyline boundary as the Outer boundary for one of the surfaces, re-build
the surface then do volume calcs for the whole Stratum. Then use the next
subarea as the Outer boundary and repeat.
> Doug Boys
> Cardno MBK Brisbane
