AutoCAD Land Desktop (Read Only)
Viewport Prolems
3 REPLIES 3
616 Views, 3 Replies
Viewport Prolems
I work in the viewport a lot from model space. Lately, I have been getting kicked out of it while panning. This will happen during either commands and/or while panning.
I just intalled the Logitech MX1000 mouse. Did anyone else have a similar problem? Does anyone know a way to correct this?
3 REPLIES 3
I wouldn't think there would be a "direct" correlation to LDT Finsternis,
for this particular issue.
Have you thought of trying one of the "vanilla" Discussion Groups - such as
Pointing-Devices and Displays:
http://tinyurl.com/r3rvo
HTH
Don Reichle
"The only thing worse
than training your staff,
and having them leave is -
not training your staff,
and having them stay."
Courtesy Graphics Solution Providers
!! Please discuss whatever we tell you with your SysMgr !!
!! They appreciate staying in the loop 🙂 !!
LDT/CD-2K4
AMD Athlon 64 X2 Dual-Core 3800+ 2.01GHz
XP-Pro 32bit SP2
2GB RAM
Dual WD800JD Hard Drives - 149GB Nvidia Stripe
Nvidia Quadro FX 1300 128MB
Dual ViewSonic 19-inch VA902b monitors
"The only Constant is Change".
wrote in message news:5240684@discussion.autodesk.com...
I did not know about this forum. Thanks Don!
I'm actually having the same problem as Branden was  However, I am using the same mouse that I've always used.  We have upgraded to AutoCad 2011 and this is the first time that I have run into this.  We stack our drawings, so we do a lot of work in paper-space.  While inside the viewport, I am getting kicked out of model-space and whatever command I am using at the time terminates.  This is a big problem, since it is slowing my productivity considerably.  Any ideas out there?
