AutoCAD Land Desktop
*Joe bouza
Post 1 of 2
Vertical transition control
315 Views, 1 Replies
07-22-2004 10:19 AM
Hi, I have not had this happen before; ldt 2004 I defined a template with left & right Horiz transition and created vertical profile in the l1 & r1 slots for the design profile. But when I look at the section only the horizontal control is taking effect even though if I edit transition the dialog box shows the elevation for the Vert transition?? Any thoughts Thanks, Joe
Member
0 Kudos
Post 2 of 2
Re: Vertical transition control
10-17-2013 11:43 AM in reply to: *Joe bouza
Did you ever figure this out? I'm having this issue with 2009. :smileyhappy:
Post to the Community
New Post
