AutoCAD Land Desktop
New Member
lucasmodric1987
Message 1 of 2 (381 Views)
Verson to Verson
381 Views, 1 Replies
02-20-2012 02:19 AM
I am currently runnin '07 while others around me are running '06. If I open a drawing and save it, other people can open it in '06 but cannot use any cogo commands (i.e. insert points or label lines). I then have to export the drawing to Autocad '04 verson and any points that are currently in the drawing have to be reinserted.
I have tried an unistall / reinstall several time but there is no difference. I also have the drawing save as set to 2004 but that does not work either.
Anyone have suggestions?
*Expert Elite*
pendean
Message 2 of 2 (357 Views)
Re: Verson to Verson
02-28-2012 06:14 AM in reply to: lucasmodric1987
Nothing you can do, it's by design: with every DWG format change there is a change in the code for custom objects in the version you use too.
If you need to share content with 2006 users, either you need to be in 2006 and use only 2006, or they need to upgrade to 2007.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
