AutoCAD Land Desktop (Read Only)
Using Pipe Node Labels
3 REPLIES 3
277 Views, 3 Replies
In our Pipes settings editor under the Node and Pipe Data Values>Node we have a node label for each of our structures filled out. I was wondering if we change a structure using our pipe editor from let's say 54" I.D. Manhole to 60" I.D. Manhole why it doesn't update the node label. It seems to hold what we used to create our pipe run with originally. Just hoping there is a way to update the node label without having to redinfe the pipe run. Thanks, Tom G.
3 REPLIES 3
Hi Thomas, You shouldn't have to redefine the run, but you certainly will need to replot (import) it to reflect the changes. -- Laurie Comerford CADApps www.cadapps.com.au "Thomas Glidewell" wrote in message news:41ec0898$1_1@newsprd01... > In our Pipes settings editor under the Node and Pipe Data Values>Node we > have a node label for each of our structures filled out. I was wondering if > we change a structure using our pipe editor from let's say 54" I.D. Manhole > to 60" I.D. Manhole why it doesn't update the node label. It seems to hold > what we used to create our pipe run with originally. Just hoping there is a > way to update the node label without having to redinfe the pipe run. > Thanks, > Tom G. > >
Thanks Laurie, Yes I am totally with you on having to re-import the pipe run in the sheet. What I was trying to get at is in the pipes editor dialog box itself will it update the node label? "Laurie Comerford" wrote in message news:41ec1b83_1@newsprd01... > Hi Thomas, > > You shouldn't have to redefine the run, but you certainly will need to > replot (import) it to reflect the changes. > > -- > > > Laurie Comerford > CADApps > www.cadapps.com.au > > "Thomas Glidewell" wrote in message > news:41ec0898$1_1@newsprd01... >> In our Pipes settings editor under the Node and Pipe Data Values>Node we >> have a node label for each of our structures filled out. I was wondering > if >> we change a structure using our pipe editor from let's say 54" I.D. > Manhole >> to 60" I.D. Manhole why it doesn't update the node label. It seems to >> hold >> what we used to create our pipe run with originally. Just hoping there is > a >> way to update the node label without having to redinfe the pipe run. >> Thanks, >> Tom G. >> >> > >
Hey Thomas; If you're discussing the Node label on the left hand side of the dialog box... You're aware that you can set the Nodes to Label or not, right? Is it possible that someone else may have turned that off on you? HTH -- Don Reichle "King Of Work-Arounds" Barghausen Consulting Engineers Kent, WA USA LDT3 - SP1/CD3 - SP1 On WIN2K SP4 Dell 1.6 Ghz P4 512MB RAM NVIDIA 32MB AGP "Thomas Glidewell" wrote in message news:41ec2a8c$1_3@newsprd01... > Thanks Laurie, > Yes I am totally with you on having to re-import the pipe run in the sheet. > What I was trying to get at is in the pipes editor dialog box itself will it > update the node label? > "Laurie Comerford" wrote in message > news:41ec1b83_1@newsprd01... > > Hi Thomas, > > > > You shouldn't have to redefine the run, but you certainly will need to > > replot (import) it to reflect the changes. > > > > -- > > > > > > Laurie Comerford > > CADApps > > www.cadapps.com.au > > > > "Thomas Glidewell" wrote in message > > news:41ec0898$1_1@newsprd01... > >> In our Pipes settings editor under the Node and Pipe Data Values>Node we > >> have a node label for each of our structures filled out. I was wondering > > if > >> we change a structure using our pipe editor from let's say 54" I.D. > > Manhole > >> to 60" I.D. Manhole why it doesn't update the node label. It seems to > >> hold > >> what we used to create our pipe run with originally. Just hoping there is > > a > >> way to update the node label without having to redinfe the pipe run. > >> Thanks, > >> Tom G. > >> > >> > > > > > > Attachment not added (too many attachments): "untitled.png"
