AutoCAD Land Desktop (Read Only)
Using AeccApplication
1 REPLY 1
231 Views, 1 Reply
Hello All,
I'm kind of new to VBA with AutoCAD programming...
What I'm trying to do seems easy enough - obtain info about the current active project in land-desktop. I have a form with a button that just flashes the name of the active project. When I execute this code, it fails on line 4 saying that the class factory can't supply the requested class. I am referencing the following libraries:
VBA, AutoCAD 2000 Type Library, OLE Automation, Microsoft Forms 2.0 Object Library, AEC Base 3.0 Application Library, AEC Base 3.3 Object Library, Autodesk Land 1.2 Type Library
1 Private Sub CommandButton1_Click()
2 ' This example returns the name of the ActivProject.
3 Dim activeProj As AeccProject
4 Set activeProj = AeccApplication.ActiveProject
5 MsgBox "The ActiveProject is: " & activeProj.Name, _
6 vbInformation, "ActiveProject Example"
7 End Sub
I guess what I need to know is how to use Aecc objects from the VBA editor in land desktop. When I use the ThisDrawing.Application.GetInterfaceObject("Aecc.Application") method of obtaining AeccApplication, I get an error saying it can't load the application. These are being launched from a macro within the open ldd, so I can't figure out what's wrong.
Any help would be appreciated!
Andrea
1 REPLY 1
Andrea
Try this. I also threw in a basic error trap to
abort if the dwg isn't attached to a project.
    Dim AecApp As new
AeccApplication
    Dim activeProj As
AeccProject
    AecApp .Init
    On Error GoTo
noProject
    Set Proj = AeccApp.ActiveProject
    On Error Goto 0
size=2>MsgBox "The ActiveProject is: " & activeProj.Name,
Exit Sub
NoProject:
'  abort if it's an unamed drawing, or it
isn't assoc with a proj
     MsgBox "Error: There must
be an active Land Project.", vbOKOnly
End Sub
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Hello
All,
What I'm trying to
libraries:
 3 Dim
 4 Set activeProj =
7 End Sub
Andrea
