AutoCAD Land Desktop (Read Only)
Unhandled Exception: App doesnt support JIT Debugging
3 REPLIES 3
Danderson12
2643 Views, 3 Replies
I am running AutoCad Civil 3-D Land Desktop Companion 2009 and when I open any drawings up I get this error message.  Not sure how to fix this.
Unhandled exception has occured in a component in your application.  If you click continue, the application will ignore this error & attempt to continue.
Invalid URI: The format of the URI could not be determined
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.UriFormatException: Invalid URI: The format of the URI could not be determined.
   at System.Uri.CreateThis(String uri, Boolean dontEscape, UriKind uriKind)
   at System.Uri..ctor(String uriString)
   at Autodesk.InfoCenter.CommunicationCenter.PopulateContents(ResultItemCollection& contentCollection, ICommCntrChannel channel)
   at Autodesk.InfoCenter.CommunicationCenter.GetContents(ResultItemCollection& channelContents)
   at Autodesk.InfoCenter.CommCntrSource.InitCommunicationCenter()
   at Autodesk.InfoCenter.PaletteMgr.get_CommCntrSrc()
   at Autodesk.InfoCenter.PaletteMgr.LoadCommCenterSources()
   at Autodesk.InfoCenter.PaletteMgr.InitCommCenter()
   at Autodesk.InfoCenter.PaletteMgr.InitSources()
   at Autodesk.InfoCenter.PaletteMgr.FirstInvoke()
   at Autodesk.InfoCenter.PaletteMgr.OnAppIdle(Object sender, EventArgs e)
   at System.Windows.Forms.Application.RaiseIdle(EventArgs e)
   at Autodesk.AutoCAD.ApplicationServices.Application.OnIdleWinForms()
   at Autodesk.AutoCAD.ApplicationServices.Application.OnIdle()
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.3623 (GDR.050727-3600)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
acdbmgd
    Assembly Version: 17.2.0.0
    Win32 Version: 17.2.56.0
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202009/AcdbMgd.DLL
System
    Win32 Version: 2.0.50727.3620 (GDR.050727-3600)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.F...
System.Drawing
    Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
PresentationFramework
    Assembly Version: 3.0.0.0
    Win32 Version: 3.0.6920.1500 built by: QFE
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework/3.0.0.0__31bf3856ad364e35/PresentationFra...
WindowsBase
    Win32 Version: 3.0.6920.1453 built by: NetFX
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationCore
    CodeBase: file:///C:/Windows/assembly/GAC_32/PresentationCore/3.0.0.0__31bf3856ad364e35/PresentationCore.dll
msvcm80
    Assembly Version: 8.0.50727.3053
    Win32 Version: 8.00.50727.3053
    CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.3053_none_d08d7bba442a9b...
acmgd
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202009/acmgd.DLL
AdWindowsWrapper
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202009/AdWindowsWrapper...
AdWindows
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.56.0
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202009/AdWindows.DLL
System.Xml
    Win32 Version: 2.0.50727.3074 (QFE.050727-3000)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
ResourceManagement
    Assembly Version: 12.0.48.0
    Win32 Version: 12.0.048.0
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202009/ResourceManageme...
AdWindows.resources
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202009/en-US/AdWindows....
PresentationFramework.Aero
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework.Aero/3.0.0.0__31bf3856ad364e35/Presentati...
AcMgdReverse
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202009/AcMgdReverse.DLL
Redland.NET
    Assembly Version: 1.0.2.1
    Win32 Version: 1.0.2.1
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202009/Redland.NET.DLL
AecDtlDb
    Assembly Version: 5.7.68.0
    Win32 Version: 5, 7, 68, 0
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202009/AecDtlDb.DLL
AecDtlDbUI
    Win32 Version: 5.7.68.0
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202009/AecDtlDbUI.DLL
AecDtlDbLib
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202009/AecDtlDbLib.DLL
AcInfoCenterConn
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202009/AcInfoCenterConn...
AdInfoCenter
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202009/AdInfoCenter.DLL
AcWindows
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202009/AcWindows.DLL
AdInfoCenter.resources
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202009/en-US/AdInfoCent...
Accessibility
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Configuration
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configura...
System.Web.Services
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Servic...
Autodesk.Interop.WSCommCntr1
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202009/Autodesk.Interop...
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
3 REPLIES 3
abennett
in reply to: Danderson12
Did anyone find any information as to this issue? I am experiencing the same issue with a user's machine. no one else is experiencing this issue.
jgahdnah
in reply to: abennett
I just started getting this message this morning. I'm not sure why.
There was no updating that happened when I shut my  computer down last night. Going to restart. hopefully that may work??
wish me luck
pendean
JIT Debugging is a Windows or IE security setting on your PC: AutoCAD and other software can't address it.
Try an Internet search and explore the many tips to turn it off.
