When you hit the button, the command line has options. Type S for settings &
then B for Block. You most likely have this function set to NONE. Try Block
or Entity. Mess around with both settings to see what they do & note that
the layer freeze command has the same options.
John Mayo
Project Engineer
Conklin Associates
Ramsey, NJ
Civil 3D 2008, LDT 2008, Raster Design 2008
P-IV at 3.5 GHz
2 GB Ram
Nvidea Quadro FX w/ 128 MB Ram
wrote in message news:5669547@discussion.autodesk.com...
By layer off (the little light bulb).
