Don't forget the icons !!
You may care to look at the Afralisp web site for all sorts of guidelines on
that issue.
Laurie Comerford
CADApps
www.cadapps.com.au
"dfarris75" wrote in message
news:824967.1095260729497.JavaMail.jive@jiveforum2.autodesk.com...
> I suppose it could be set up that way, but if you have created toolbars on
your local computer then it writes that info to the .mns file which is
located on your computer. It would have to be copied to the .mnu file. It
depends on how you created your toolbars and whether or not you already
copied that info to the .mnu file.
