[img src="@162755"]
1. AT SYM MANAGER PRESS MANAGE
2.SYMBOL SET:
existing: give your SS a name
Key: give a corresponding KEY
name
Description: Ditto
File: give a unique file name
<name>.dbf
check import symbols
3. Press Add Key
[img src="@162756"]
give a name ( hint : use the names from 2)
Value: enter path to symbols ( make sure it is exactly
correct)
4. Pattern if you want to filter files here is you
chance
set defaults
( insert layer, scales, lisp routines ....)
set Cat..palett..( here you can organize by drag and drop...
5. see 4.
6. check create slides ( my screen shot shows new
only but all would be good)
7. slide library ( if you need one here is your
chance)
8. press OK. each file will be
opened so be on hand for this step; you get to accept the file name for the
symbol name or edit on command line.
Wheew! That will do it.
Foot note: if you are sharing as I suspect ... Set
the dbf file to a network location That will take some tinkering... once
you get your share business squared away the easiest way to get all your users
to see them is to copy YOUR SDSK.dfm file to all THERE machines. ( please make
back up copies first)
Good Luck
Joe
Joseph D. Bouza, P.E.
Civil 3D 2006
LDT
2006
Win XP pro
v 2002, sp 2
hp workstation
xw4100
In
memory of the King of Work-arounds
"The only Constant is
Change".
"The only thing worse than training your staff, and
having them leave is -
not training your staff, and having them stay."
:-o
A reminder taken from Graphics Solution Providers' Calendar
page
i guess i need to know how to
start a new one, because i think i am not starting the process correctly.
i make a new folder in the symbol manager folder with all the symbols i am going
to be needing. then i go to the symbol manager to try to create a new
symbol set. that's where i get lost. i've tried several different
things and can't get it to work. maybe if you could let me know how to do
it from the start.
thanks
