ssamaniego said the following on 1/17/2006 3:27 PM:
> AUTOCAD LAND DESKTOP 2006 ISSUE: My company has put together custom
> tool palettes and a custom symbol manager. When I insert the blocks
> from the symbol manager everything works fine but when I insert the
> blocks from the tool palettes the block inserts at 1/12 scale. I
> talked with CAD Masters and they have told me to use the command
> INSUNITS to eliminate this problem but I would need to do this with
> every drawing each time I open it. Does anyone know of a way to have
> both custom block libraries work together, the same way?
> thanks!
Make sure INSUNITS = 0, and life is good.
Set it to 0 in your template drawing(s) to start with.
Add this to your "acaddoc.lsp" also:
(if (not (zerop (getvar "insunits")))(setvar "insunits" 0))
There should be no need to change all your existing blocks.
R.K. McSwain
http://rkmcswain.blogspot.com
