AutoCAD Land Desktop (Read Only)
Survey template set-up in Land Desktop
1 REPLY 1
colinco
1257 Views, 1 Reply
I was recently working with land desktop and when importing surveys with specific codes land desktop automatically assigned blocks to the codes i.e tress and manholes. i still have access to this computer and it would be a great time-saver if this template could be tranferred to my new cad program which is autocad 3d map. Failing this , is there a way to set this up in 3d map from scratch. thanks
1 REPLY 1
sboon
in reply to: colinco
Land Desktop uses something called a Description Key to assign point symbols based on the survey descriptions.  This function is also available within Civil3d, but not the ACad Map software.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
